11-21-2017
03:19 AM
- Mute
- Permalink
- Report
11-21-2017
03:19 AM
The Code below gave me the error code:
System.NullReferenceException: Object reference not set to an instance of an object.
at iLogic.CadAssemblyUtil.FindComponentOccurrence(Document rootDoc, Object compoName, Boolean topLevelOnly, Boolean inTopLevelContext)
at iLogic.CadCompoOrDoc..ctor(Document rootDoc, Object oName)
at iLogic.ParamDynamicFinder.GetParameterInCompoOrDoc(Object compoOrDocName, String paramName)
at iLogic.ParamDynamic.get_Item(Object compoOrDocName, String paramName)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
SyntaxEditor Code Snippet
Select Case Parameter("15231.10:1", "Conveyor_Length") Case <=7000 ActiveSheet.View("VIEW1").Scale=1/45 ActiveSheet.View("VIEW3").Scale=1/55 ActiveSheet.View("VIEW5").Scale=1/55 Case <=11000 ActiveSheet.View("VIEW1").Scale=1/65 ActiveSheet.View("VIEW3").Scale=1/75 ActiveSheet.View("VIEW5").Scale=1/65 Case <=15000 ActiveSheet.View("VIEW1").Scale=1/85 ActiveSheet.View("VIEW3").Scale=1/95 ActiveSheet.View("VIEW5").Scale=1/85 End Select
When removed the code worked just fine, just without the parameter based scaling.
