- Mute
- Permalink
- Report
IDW ilogic reference point error
I have an issue with an .idw where im trying to work out a rule in iLogic that will scale my views depending on the length of a pipe that i have drawn. An example is that if the length is above 7000mm the scale is 1:55, and above 11000 the scale is 1:75 .
I have four views, the 3 normal ISO standard views + a 3D.
the code i have now gives me the error: "Object reference not set to an instance of an object."
Im assuming its the .SetSpacingToCorner code that gives me the error, and this feature is not important, i just need them splitted apart.
here is the code:
SyntaxEditor Code Snippet
If Parameter("15231.10:1", "Conveyor_Lenght")<=7000 ActiveSheet.View("VIEW1").Scale=1/45 ActiveSheet.View("VIEW3").Scale=1/55 ActiveSheet.View("VIEW5").Scale=1/55 ActiveSheet.View("VIEW1").SetSpacingToCorner(20, 80, SheetCorner.BottomLeft) ActiveSheet.View("VIEW2").SetSpacingToCorner(230, 90, SheetCorner.BottomLeft) ActiveSheet.View("VIEW3").SetSpacingToCorner(280, 40, SheetCorner.BottomLeft) ActiveSheet.View("VIEW5").SetSpacingToCorner(280, 90, SheetCorner.BottomLeft) Else If Parameter("15231.10:1", "Conveyor_Lenght")<=11000 ActiveSheet.View("VIEW1").Scale=1/65 ActiveSheet.View("VIEW3").Scale=1/75 ActiveSheet.View("VIEW5").Scale=1/65 ActiveSheet.View("VIEW1").SetSpacingToCorner(20, 80, SheetCorner.BottomLeft) ActiveSheet.View("VIEW2").SetSpacingToCorner(230, 90, SheetCorner.BottomLeft) ActiveSheet.View("VIEW3").SetSpacingToCorner(280, 40, SheetCorner.BottomLeft) ActiveSheet.View("VIEW5").SetSpacingToCorner(280, 90, SheetCorner.BottomLeft) Else If Parameter("15231.10:1", "Conveyor_Lenght")<=15000 ActiveSheet.View("VIEW1").Scale=1/85 ActiveSheet.View("VIEW3").Scale=1/95 ActiveSheet.View("VIEW5").Scale=1/85 ActiveSheet.View("VIEW1").SetSpacingToCorner(20, 80, SheetCorner.BottomLeft) ActiveSheet.View("VIEW2").SetSpacingToCorner(230, 90, SheetCorner.BottomLeft) ActiveSheet.View("VIEW3").SetSpacingToCorner(280, 40, SheetCorner.BottomLeft) ActiveSheet.View("VIEW5").SetSpacingToCorner(280, 90, SheetCorner.BottomLeft) End If ' Set a reference to the active drawing document Dim oDoc As DrawingDocument oDoc = ThisDoc.Document ' Set a reference to the active sheet Dim oSheet As Sheet oSheet = oDoc.ActiveSheet Dim oDrawingDim As DrawingDimension ' Iterate over all dimensions in the drawing and ' center them if they are linear or angular. For Each oDrawingDim In oSheet.DrawingDimensions If TypeOf oDrawingDim Is LinearGeneralDimension Or _ TypeOf oDrawingDim Is AngularGeneralDimension Then oDrawingDim.CenterText End If Next InventorVb.DocumentUpdate()
Any help?
Thank you in advance.
-A
- Mute
- Permalink
- Report
See my signature for some documentation on debugging manually in iLogic.
Also, "lenght" vs "length".
Select Case Parameter("15231.10:1", "Conveyor_Length")
Case <=7000
Case <=11000
Case <=15000
End Select
Dim oSheet As Sheet
End If
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
Hi Again,
I still get the error:
Error in rule: Rule0, in document: 15231.30.idw
- Mute
- Permalink
- Report
The Code below gave me the error code:
System.NullReferenceException: Object reference not set to an instance of an object.
at iLogic.CadAssemblyUtil.FindComponentOccurrence(Document rootDoc, Object compoName, Boolean topLevelOnly, Boolean inTopLevelContext)
at iLogic.CadCompoOrDoc..ctor(Document rootDoc, Object oName)
at iLogic.ParamDynamicFinder.GetParameterInCompoOrDoc(Object compoOrDocName, String paramName)
at iLogic.ParamDynamic.get_Item(Object compoOrDocName, String paramName)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Select Case Parameter("15231.10:1", "Conveyor_Length") Case <=7000 ActiveSheet.View("VIEW1").Scale=1/45 ActiveSheet.View("VIEW3").Scale=1/55 ActiveSheet.View("VIEW5").Scale=1/55 Case <=11000 ActiveSheet.View("VIEW1").Scale=1/65 ActiveSheet.View("VIEW3").Scale=1/75 ActiveSheet.View("VIEW5").Scale=1/65 Case <=15000 ActiveSheet.View("VIEW1").Scale=1/85 ActiveSheet.View("VIEW3").Scale=1/95 ActiveSheet.View("VIEW5").Scale=1/85 End Select
When removed the code worked just fine, just without the parameter based scaling.
