Or you could use the inventor built in as you needed!
This will completely fulfill your needs I think?
Dim a As Application
Set a = ThisApplication
Dim b As Balloontip
Set b = a.UserInterfaceManager.BalloonTips.Add("String Name", "String Title", "Watch out")
b.Display
Arthur Knoors
Autodesk Affiliations:
Tags (1)
