- Mute
- Permalink
- Report
Hi
- Mute
- Permalink
- Report
Not for the Communication Center:
But I use the Balloontip from Windows.
Public Sub Balloontip(StrTitle As String, StrText As String, Time As Integer)
Dim NotIcon As System.Windows.Forms.NotifyIcon
NotIcon = New System.Windows.Forms.NotifyIcon
NotIcon.Icon = System.Drawing.SystemIcons.Information
NotIcon.BalloonTipTitle = StrTitle
NotIcon.BalloonTipText = StrText
NotIcon.BalloonTipIcon = Windows.Forms.ToolTipIcon.Info
NotIcon.Visible = True
NotIcon.ShowBalloonTip(Time)
End Sub
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
Or you could use the inventor built in as you needed!
This will completely fulfill your needs I think?
Dim a As Application
Set a = ThisApplication
Dim b As Balloontip
Set b = a.UserInterfaceManager.BalloonTips.Add("String Name", "String Title", "Watch out")
b.Display
Arthur Knoors
