- Mute
- Permalink
- Report
then what parameters do you need to change?
This is very basic I-logic and programming and should be possible very easily.
But I do not know exactly what needs to be changed and how the model file is generated.
Please give more info regarding the parameters to be changed and in what value and unit and expression.
Arthur Knoors
Autodesk Affiliations:
