731 Views, 4 Replies
Collect values of iProperties from sub components
I would like to loop through all referenced documents of any assembly and collect the values of an array of iProperties and present their totals as an iProperty in the assembly.
For example, the iProperties I'm searching through are called PUNCH, FORM, WELD
There are various sub-parts with these iProperties and they all have a numerical value (of type Text)
I wish to populate my assembly iProperties (PUNCH, FORM, WELD) with the combined totals of all the sub parts.
This is what I've tried so far (its incomplete as still need to make use of the array of iProp names) but it's failing at the first hurdle !! Can't get it to return the value from the function back to the sub. Can anyone help or suggest a more efficient way?
Its definitely finding values, I can see when I uncomment the message box in the function that shows the value of FORM
Sub Main ()
Dim oDoc As Document = ThisApplication.ActiveDocument
If oDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
Dim oADO As Inventor.ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
iProperties.Value("Custom", "FORM") = 0
iProperties.Value("Custom", "PUNCH") = 0
iProperties.Value("Custom", "WELD") = 0
For Each aDoc As Document In oDoc.AllReferencedDocuments
If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Dim oAssmDoc As AssemblyDocument = aDoc
oDef = oAssmDoc.ComponentDefinition
ElseIf aDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oPartDoc As PartDocument = aDoc
oDef = oPartDoc.ComponentDefinition
End If
' MyOperations = New String(){"FORM", "PUNCH", "WELD"}
' For Each op in MyOperations
' MsgBox(op)
' Next
If oDef.BOMStructure <> BOMStructureEnum.kPhantomBOMStructure
      Dim Amount As Integer = oADO.AllReferencedOccurrences(aDoc).Count
      collectQuantity(aDoc,Amount,oLibraryPath)
End If
FORM_QTY = FORM_QTY + FORM
Next
iProperties.Value("Custom", "FORM") = FORM_QTY
End Sub
Function collectQuantity (aDoc As Document, Amount As Integer,oLibraryPath As String) As Double
Dim oPropsets As PropertySets = aDoc.PropertySets
Dim oCustomPropSet As PropertySet = oPropsets.Item("User Defined Properties")
Dim FORM As Double
Try
FORM =  oCustomPropSet("FORM").Value * Amount
'MsgBox(FORM)
Catch
FORM = 0
End Try
Return FORM
End Function
