- Mute
- Permalink
- Report
I would like to loop through all referenced documents of any assembly and collect the values of an array of iProperties and present their totals as an iProperty in the assembly.
For example, the iProperties I'm searching through are called PUNCH, FORM, WELD
There are various sub-parts with these iProperties and they all have a numerical value (of type Text)
I wish to populate my assembly iProperties (PUNCH, FORM, WELD) with the combined totals of all the sub parts.
This is what I've tried so far (its incomplete as still need to make use of the array of iProp names) but it's failing at the first hurdle !! Can't get it to return the value from the function back to the sub. Can anyone help or suggest a more efficient way?
Its definitely finding values, I can see when I uncomment the message box in the function that shows the value of FORM
Sub Main ()
Dim oDoc As Document = ThisApplication.ActiveDocument
If oDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
Dim oADO As Inventor.ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
iProperties.Value("Custom", "FORM") = 0
iProperties.Value("Custom", "PUNCH") = 0
iProperties.Value("Custom", "WELD") = 0
For Each aDoc As Document In oDoc.AllReferencedDocuments
If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Dim oAssmDoc As AssemblyDocument = aDoc
oDef = oAssmDoc.ComponentDefinition
ElseIf aDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oPartDoc As PartDocument = aDoc
oDef = oPartDoc.ComponentDefinition
End If
' MyOperations = New String(){"FORM", "PUNCH", "WELD"}
' For Each op in MyOperations
' MsgBox(op)
' Next
If oDef.BOMStructure <> BOMStructureEnum.kPhantomBOMStructure
Dim Amount As Integer = oADO.AllReferencedOccurrences(aDoc).Count
collectQuantity(aDoc,Amount,oLibraryPath)
End If
FORM_QTY = FORM_QTY + FORM
Next
iProperties.Value("Custom", "FORM") = FORM_QTY
End Sub
Function collectQuantity (aDoc As Document, Amount As Integer,oLibraryPath As String) As Double
Dim oPropsets As PropertySets = aDoc.PropertySets
Dim oCustomPropSet As PropertySet = oPropsets.Item("User Defined Properties")
Dim FORM As Double
Try
FORM = oCustomPropSet("FORM").Value * Amount
'MsgBox(FORM)
Catch
FORM = 0
End Try
Return FORM
End Function
- Mute
- Permalink
- Report
I think your issue was that you weren't returning FORM from your function to a variable.
Sub Main ()
Form = 0
End If
' MsgBox(op)
' Next
Form = collectQuantity(aDoc,Amount,oLibraryPath)
End If
FORM_QTY = FORM_QTY + Form
Next
End Sub
Dim FORM As Double
Try
'MsgBox(FORM)
Catch
FORM = 0
End Try
Return FORM
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
@MechMachineMan thanks for picking that up. I'll give it a shot tomorrow when I'm back at my PC. I was originally trying it in a Sub instead of a function but was not having any joy. Should I be able to set the value of a variable in a Sub & have the Sub Main continue with that value?
- Mute
- Permalink
- Report
Only if you designate the variable as ByRef in the function declaration.
Sub Main()
x = 2
Call DoMath(x)
MsgBox(x)
'x = 2 returns 2 if ByVal
'x = 2 returns 4 if ByRef
End Sub
'Sub DoMath(ByVal variable As integer)
Sub DoMath(ByRef variable As integer)
variable = variable + variable
End Sub
- Mute
- Permalink
- Report
Here is my final code. Its functioning correctly but takes a long time to process. That's due to my large array of properties to search for in every part, even though most of my documents only have 2 or 3 of these properties in them.
Any suggestions on how to make it more efficient?
Sub Main () 'define the file to create/open Dim oDoc As Document = ThisApplication.ActiveDocument If oDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub Dim oProjectMgr As DesignProjectManager oProjectMgr = ThisApplication.DesignProjectManager ' Get the active project Dim oProject As DesignProject oProject = oProjectMgr.ActiveDesignProject Dim oLibraryPaths As ProjectPaths oLibraryPaths = oProject.LibraryPaths ' look at all library paths Dim oLibraryPath As String = oProject.LibraryPaths.Item(1).Path Dim oADO As Inventor.ComponentOccurrences = oDoc.ComponentDefinition.Occurrences MyOperations = New String(){"SAW_SET","SAW_RUN","CNCF_SET","CNCF_RUN","SS_SET","SS_RUN","PUNCH_SET","PUNCH_RUN","FORM_SET","FORM_RUN","WELD_SET","WELD_RUN","CNCC_SET","CNCC_RUN","JOINERY_SET","JOINERY_RUN","FASSY_SET","FASSY_RUN","SANDING_RUN","PCOAT_SET","PCOAT_RUN","COMP_SET","COMP_RUN","GLASS_SET","GLASS_RUN","BPG_SET","BPG_RUN","BOND_SET","BOND_RUN","WPAINT_SET","WPAINT_RUN","PANFIN_SET","PANFIN_RUN","CASSY_SET","CASSY_RUN","PACK_SET","PACK_RUN"} For Each Operation In MyOperations
OpName = Left(Operation,Len(Operation)-4) Try iProperties.Value(OpName & ":1","Custom", "QTY") = 0 Catch MsgBox(OpName & ":1 does not exist.") Exit Sub End Try Next For Each aDoc As Document In oDoc.AllReferencedDocuments If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim oAssmDoc As AssemblyDocument = aDoc oDef = oAssmDoc.ComponentDefinition ElseIf aDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim oPartDoc As PartDocument = aDoc oDef = oPartDoc.ComponentDefinition End If If oDef.BOMStructure <> BOMStructureEnum.kPhantomBOMStructure And Not aDoc.FullFileName.Contains(oLibraryPath) 'MsgBox(aDoc.FullFileName) Dim Amount As Integer = oADO.AllReferencedOccurrences(aDoc).Count For Each Operation In MyOperations OpQTY = 0 OpQTY = collectQuantity(aDoc,Amount,Operation) 'MsgBox(OP_QTY)
OpName = Left(Operation,Len(Operation)-4) iProperties.Value(OpName & ":1","Custom", "QTY") += OpQTY Next End If Next End Sub Function collectQuantity (aDoc As Document, Amount As Integer,Op As String) As Double Dim oPropsets As PropertySets = aDoc.PropertySets Dim oCustomPropSet As PropertySet = oPropsets.Item("User Defined Properties") Dim Op_Qty As Double Try Op_Qty = oCustomPropSet(Op).Value * Amount 'MessageBox.Show(Op & "---" & Op_Qty,aDoc.DisplayName) Catch Op_Qty = 0 End Try Return Op_Qty End Function
