- Mute
- Permalink
- Report
Matt,
I do a similar thing (import to inventor from xml)
My xml format may be slightly different, but here is some of the code that i use.
I use VBA to do this - example below.
I hope you can figure out what you need to change, based on this example.
Dean.
'I have a reference to Microsoft XML v3.0
xmlfile = "C:\xml.xml" 'Path to xml file
Set objXML = New MSXML2.DOMDocument
objXML.Load xmlfile
'For a normal node
Set xmlElem = objXML.selectSingleNode("//NodeName")
If Not xmlElem Is Nothing Then
oNodeName = xmlElem.Text
End If
'For a node with children
Set xmlElem = objXML.selectNodes("//NodeNamewithchildren")
oNodeNamewithchildren = xmlElem.ChildNodes.Item(0).Text 'index for child node
End IF
'To apply the xml node value to a User Paramater
Dim oFileLocations As FileLocations
Set oFileLocations = ThisApplication.FileLocations
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Open(oFileLocations.Workspace & "/Part.ipt")
Dim oPartCompDef As PartComponentDefinition
Set oPartCompDef = oPartDoc.ComponentDefinition
Dim oParams As UserParameters
Set oParams = oPartCompDef.Parameters.UserParameters
oParams.Item("ParameterName").Expression = oNodeName
oParams.Item("ParameterName").Expression = oNodeNamewithchildren
oPartDoc.Save2 (True)
oPartDoc.Close
