1346 Views, 1 Reply
map xml to user parameters in ilogic or vb
I am trying parse and import parameters from an .xml file into inventor. I've attached the file for reference.
The file I've attached is an output from a home-grown design program for one of the products we use. It spits out this file to be read by our ERP system downstream of Engineering. I would also like to use it to populate my model with parameters so the drawing is generated automatically.
For example, the material_thickness nodes correspond to steel plate thicknesses, and the lenght/width correspond to steel plate rectangular dimensions. There are also bolt diameters and other parameters I would like to read.
I know there is an out of the box import/export xml parameters, but from what I understand the xml has to be formatted a specific way. I would like to map this existing schema to user parameters in my model. If someone could send me an ilogic or vb code snippet that would be great.
Matt
