- Mute
- Permalink
- Report
Complete Automation iLogic / Rule
Reference Post: ilogic-rule-help
Hello All,
Thank you Kevin for raising this problem and thank you Machine Man for a compelling solution. However I am on a crusade to achieve 100% automation in a similar assembly only mine is a bit more complex thus the aim of complete automation.
Now as per all the solutions suggested in this thread, my key concern is that when solving such a problem with ilogic I run into the problem that although with patterns I can add lines to the skeletal model that drives the assembly I am unable to automate anything with frame generator (lack of API level access) thus every time my template size is reduced (from maximum occurrences to required number) to fit the requirement I am left with extra frame sections that have no reference sketch.
I have been experimenting with icopy but can't find any code that helps me call that function.
Please help.
Thank you.
