pball
in reply to: bespel
Here is an iLogic script I made to count the surface area of colors on parts in an assembly. If you replace the color with material and surface area with weight this script should work for you. I don't have time to tweak this now, but if you need help someone could probably help out before I get time.
https://forums.autodesk.com/t5/inventor-forum/how-do-i-get-inventor-to-calculate-and-sum-up-painted-...
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
