chandra.shekar.g
in reply to: GeorgK
Hi @GeorgK,
Hope the following screencast link would help.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/screencast/Main/Details/...
In this screencast video, workpoint is created at one of the end point. Then, workpoint is patterned along curve length.
Similarly, a rectangle patterned part is attached with this post. Here, pattern count is calculated by measuring length of curve divided by offset length.
Can you please provide sample part to test? please make sure that part is non confidential one.
Please feel free to contact if there is any queries.
If problem is solved, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
