chandra.shekar.g
in reply to: GeorgK
Hi @GeorgK,
You could try the following VBA code. Here, only part occurrences are considered.
Sub Main()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oUCS As UserCoordinateSystem
    Set oUCS = ThisApplication.CommandManager.Pick(kUserCoordinateSystemFilter, "Select UCS")
    Dim occDef As ComponentDefinition
    Set occDef = oUCS.Parent
    Dim occ As ComponentOccurrence
    Dim occMatrix As Matrix
    For Each occ In oDef.Occurrences.AllLeafOccurrences
        If occ.Definition Is occDef Then
            Set occMatrix = occ.Transformation
            Exit For
        End If
    Next
    If occMatrix Is Nothing Then
        Debug.Print ("UCS occurrence not found")
    Else
        Dim oMatrix As Matrix
        Set oMatrix = oUCS.Transformation
        Call oMatrix.TransformBy(occMatrix)
        Dim oUCSDef As UserCoordinateSystemDefinition
        Set oUCSDef = oDef.UserCoordinateSystems.CreateDefinition
        oUCSDef.Transformation = oMatrix
        Dim copiedUCS As UserCoordinateSystem
        Set copiedUCS = oDef.UserCoordinateSystems.Add(oUCSDef)
    End If
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
