- Mute
- Permalink
- Report
Points on 3D spline
Hello together,
how could I get the points on a 3D spline? The points should be calculated for example 2mm along the spline.
I could export the points:
http://modthemachine.typepad.com/my_weblog/2011/06/writing-work-points-to-an-excel-file.html
Thank you Georg
- Mute
- Permalink
- Report
Hey Georg,
Was the 3d spline created with the points? If so, it is convenient to get the sketch points by SketchSpline3d.FitPoint(Index) in Inventor.
Jane Fan
Inventor QA Engineer
- Mute
- Permalink
- Report
Hey Georg,
Please find the following code to get some hint, which adds all fit points of a spline 3d to an object collection
Sub splintPts()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSk3d As Sketch3D
Set oSk3d = oDoc.ComponentDefinition.Sketches3D(1)
Dim oSkSpline As SketchSpline3D
Set oSkSpline = oSk3d.SketchSplines3D.Item(1)
Dim objCol As ObjectCollection
Set objCol = ThisApplication.TransientObjects.CreateObjectCollection
For i = 1 To oSkSpline.FitPointCount
Call objCol.Add(oSkSpline.FitPoint(i))
Next
Debug.Print objCol.Count
End Sub
Jane Fan
- Mute
- Permalink
- Report
Hi @GeorgK,
Hope the following screencast link would help.
In this screencast video, workpoint is created at one of the end point. Then, workpoint is patterned along curve length.
Similarly, a rectangle patterned part is attached with this post. Here, pattern count is calculated by measuring length of curve divided by offset length.
Can you please provide sample part to test? please make sure that part is non confidential one.
Please feel free to contact if there is any queries.
If problem is solved, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
- Mute
- Permalink
- Report
Hello @chandra.shekar.g,
I thought that there could be a possibility to calculate the points directly. I have a robot which should drive along the spline. There are a lot of calculations to this.
Thanks Georg
- Mute
- Permalink
- Report
Hi @GeorgK,
Unfortunately, there is no direct approach to calculate the points along spline.
Please post this wish list at idea station using following link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
