Here is my complete Code to loop throught the assembly, only for files that are write enabled!
Public Sub SaveAllDesign(oTopDoc As Document)
        Dim fioTop As System.IO.FileInfo = New System.IO.FileInfo(oTopDoc.FullFileName)
        If fioTop.IsReadOnly = False Then
            Dim oInvDoc As Document
            For Each oInvDoc In oTopDoc.ReferencedDocuments
                Dim fio As System.IO.FileInfo = New System.IO.FileInfo(oInvDoc.FullFileName)
                If fio.IsReadOnly = False Then
                    'MsgBox(oInvDoc.FullFileName)
                    oInvDoc.Save()
                    If oInvDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                        Try
                            SaveAllDesign(oInvDoc)
                        Catch ex As Exception
                        End Try
                    End If
                    If oInvDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                        Try
                        End Try
                    End If
                End If
            Next
        End If
    End Sub
Arthur Knoors
Autodesk Affiliations:
Tags (1)
