- Mute
- Permalink
- Report
You have already given yourselves the answer I think to the point o build in code.
Using Add-ins and dll’s has the following advantages:
- Reuseability of the coding
- More flexible when changes are needed.
- Is not build into files.
- More flexible because the complete API is available.
- More flexible and easier regarding file managment
- Afterward you will see that it is easier
Regarding the location of the add in files the following:
Hi, You have already given yourselves the answer I think to the point o build in code. Using Add-ins and dll’s has the following advantages: • Reuseability of the coding • More flexible when changes are needed. • Is not build into files. • More flexible because the complete API is available. • More flexible and easier regarding file managment • Afterward you will see that it is easier • …… Regarding the location of the add in files the following:
Hope this will change your mind.
I you need help I am willing to!
Arthur Knoors
Autodesk Affiliations:
