bradeneuropeArthur
General remark to this:
you should start programming your own add-ins to be flexible to this point.
Coding in the parts or assemblies is not that flexible as you can see now.
Actually it is not that difficult to program your own add ins if you familiar with I-logic!
Afterward you will see the benefits of add-ins.
Arthur Knoors
Autodesk Affiliations:
