- Mute
- Permalink
- Report
I'll do what I can, but all this is much, much easier if you provide a copy of your assembly file.
Open your assembly fresh, delete the previous troublesome rules, and go to your iLogic browser. click the far-right tab "External Rules", and right-click "Manually Added", then select "Create New External Rule". Navigate to the directory where you want the external rule saved. Name the first rule "DescriptionEditor". Paste in the following:
SyntaxEditor Code Snippet
TempString = iProperties.Value("Project", "Part Number") iProperties.Value("Project", "Description") = TempString iProperties.Value("Project", "Part Number") = ""
Now create another external rule, save it in the same directory, and call it "ChangeDescription". Paste in the following:
oCompDef = ThisDoc.Document.ComponentDefinition oAssyOccurrences = ThisDoc.Document.ComponentDefinition.Occurrences iLogicVb.RunRule("Test") Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAssyOccurrences If oSubOccurrence1.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then iLogicVb.RunExternalRule("ChangeDescription") End If Next
Now go to your "Manage" tab at the top, and look in the iLogic section of the ribbon. Click "Event Triggers". Make sure the top-left box (Run these rules when events occur) is checked. Highlight "Before Save Document" and click the "Select Rules..." button at the bottom. Check the box beside the line that ends in "ChangeDescription" and click OK.
Now that all of that is done, when you save your file, the iProperty "Description" should be the previous part number, and "Part Number" should be blank.
