11-01-2017
11:44 AM
- Mute
- Permalink
- Report
11-01-2017
11:44 AM
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Sub Main()
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim oRefDoc As Document
For Each oRefDoc In oAsmDoc.AllReferencedDocuments
oDTP = oRefDoc.PropertySet("Design Tracking Properties")
TempString =oDTP("Part Number").Value
oDTP("Part Number").Value = oDTP("Description").Value
oDTP("Description").Value = oTempString
Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
