MechMachineMan
For 1; proper nesting makes things easier to read and understand.
For 2; your code only goes 2 levels deep in the assembly, and it becomes evident you are not a programmer.
- To dig through all levels of assembly, you almost certainly need recursion. See the attached link that will provide you some better guidance on the topic.
http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Proper nesting shown below:
oCompDef = ThisDoc.Document.ComponentDefinition
oAssyOccurrences  = oCompDef.Occurrences
Dim oOccurrence As ComponentOccurrence
Dim oSubOccurrence1 As ComponentOccurrence
For Each oOccurrence In oAssyOccurrences If oOccurrence.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
iLogicVb.RunRule(oOccurrence.Name,"Test") For Each oSubOccurrence1 In oOccurrence.SubOccurrences If oSubOccurrence1.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then iLogicVb.RunRule(oSubOccurrence1.Name,"Test") End If Next End If Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
