LARA-Engineering
916 Views, 3 Replies
set units from US to ISO
after installing and already working with 2018, I discovered all my physical material units are set to US (psi, lb, F, etc.)
This should be ISO (MPa, N, kg, C etc.)
How is this possible and how can I change to ISO ?
The document setting are ISO !!
Freddy de Jong
LARA Engineering
Rob67ert
in reply to: LARA-Engineering
In the Material browser, the lower left icon, Set Display Units.
Safe it to your default template file.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
LARA-Engineering
in reply to: Rob67ert
thanks a lot,
so many set-up options, you dont see the most simplest anymore  Smiley Frustrated
Freddy de Jong
LARA Engineering
Rob67ert
No problem.
First I thought the all the setting would be in one or 2 places; Document and Application setting.
But you still have some settings in your .ipj, your iLogic Configuration, the units in your material...and I guess I forgot a few.
Robert
