GeorgK
1481 Views, 11 Replies
Copy UCS from part to assembly
Hello together,
I have a part with a UCS inside. This part is placed in an assembly. I would like create a new UCS in the assembly with the same orientation as the part UCS.
 Dim oDoc As Document
        oDoc = m_invApp.ActiveDocument
        Dim CompDefs As AssemblyComponentDefinitions
        CompDefs = oDoc.ComponentDefinitions
        Dim oCompDef As AssemblyComponentDefinition
        oCompDef = CompDefs.Item(1)
        Dim oWx As Inventor.WorkAxis
        oWx = m_invApp.CommandManager.Pick(SelectionFilterEnum.kWorkAxisFilter, "Please select WorkAxis:")
        If oWx.IsCoordinateSystemElement Then
            Dim oWxNodeDef As Inventor.NativeBrowserNodeDefinition
            Dim oWxNode As Inventor.BrowserNode
            oWxNodeDef = oDoc.BrowserPanes.GetNativeBrowserNodeDefinition(oWx)
            oWxNode = oDoc.BrowserPanes.ActivePane.TopNode.AllReferencedNodes(oWxNodeDef).Item(1)
            Dim oUCS As Inventor.UserCoordinateSystem
            oUCS = oWxNode.Parent.NativeObject
            Dim oTransMatrix As Matrix
            oTransMatrix = oUCS.Transformation
        End If
How could I do this?
Georg
