- Mute
- Permalink
- Report
Hello together,
I have a part with a UCS inside. This part is placed in an assembly. I would like create a new UCS in the assembly with the same orientation as the part UCS.
Dim oDoc As Document
oDoc = m_invApp.ActiveDocument
Dim CompDefs As AssemblyComponentDefinitions
CompDefs = oDoc.ComponentDefinitions
Dim oCompDef As AssemblyComponentDefinition
oCompDef = CompDefs.Item(1)
Dim oWx As Inventor.WorkAxis
oWx = m_invApp.CommandManager.Pick(SelectionFilterEnum.kWorkAxisFilter, "Please select WorkAxis:")
If oWx.IsCoordinateSystemElement Then
Dim oWxNodeDef As Inventor.NativeBrowserNodeDefinition
Dim oWxNode As Inventor.BrowserNode
oWxNodeDef = oDoc.BrowserPanes.GetNativeBrowserNodeDefinition(oWx)
oWxNode = oDoc.BrowserPanes.ActivePane.TopNode.AllReferencedNodes(oWxNodeDef).Item(1)
Dim oUCS As Inventor.UserCoordinateSystem
oUCS = oWxNode.Parent.NativeObject
Dim oTransMatrix As Matrix
oTransMatrix = oUCS.Transformation
End If
How could I do this?
Georg
- Mute
- Permalink
- Report
Hi @GeorgK,
In order to copy UCS from part to assembly, UserCoordinateSystemProxy can be created from part and copied into AssemblyDocument.
To illustrate the same,
- Launch Inventor 2018
- open new assembly document
- Download attached part(UCS part.ipt) to desired location
- Copy and paste the following VBA code into VBA editor.
- Update the path of part in VBA code.
- On running the code, a UCS will be copied from part to assembly.
Sub Main()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim occMatrix As Matrix
Set occMatrix = ThisApplication.TransientGeometry.CreateMatrix
Dim occ As ComponentOccurrence
Set occ = oDef.Occurrences.Add("Path of part files\UCS part.ipt", occMatrix)
Dim compDef As PartComponentDefinition
Set compDef = occ.Definition
Dim partUCS As UserCoordinateSystem
Set partUCS = compDef.UserCoordinateSystems.Item(1)
Dim oProxy As UserCoordinateSystemProxy
Call occ.CreateGeometryProxy(partUCS, oProxy)
Dim oMatrix As Matrix
Set oMatrix = oProxy.Transformation
Dim oUCSDef As UserCoordinateSystemDefinition
Set oUCSDef = oDef.UserCoordinateSystems.CreateDefinition
oUCSDef.Transformation = oMatrix
Dim oUCS As UserCoordinateSystem
Set oUCS = oDef.UserCoordinateSystems.Add(oUCSDef)
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
- Mute
- Permalink
- Report
Hello @chandra.shekar.g,
is it possible to select the UCS directly? I have several parts with different UCS in each part.
Thank you for your help.
Georg
- Mute
- Permalink
- Report
Hi @GeorgK,
Try the following VBA code to select the UCS and create the same in AssemblyDocument.
Sub Main()
Set oUCS = ThisApplication.CommandManager.Pick(kUserCoordinateSystemFilter, "Select UCS")
Set oMatrix = oUCS.Transformation
Dim copiedUCS As UserCoordinateSystem
Set copiedUCS = oDef.UserCoordinateSystems.Add(oUCSDef)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
your code does not position the UCS in the assembly at the position where the part with the UCS is. The part includes the UCS.
Thank you Georg
- Mute
- Permalink
- Report
Hi @GeorgK,
Try the following VBA code to copy UCS from part to assembly. Here, location of part occurrence plays important role in copying UCS. So, occurrence selection is required to copy UCS.
Sub Main()
Set occ = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select occurrence from which UCS need to copy")
Set occMatrix = occ.Transformation
Call oMatrix.TransformBy(occMatrix)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
thank you very much. Now I understand the transformation. That's great. Is it possible to get the occurrence from the UCS by code?
Georg
- Mute
- Permalink
- Report
Hi @GeorgK,
Try the following VBA code which takes occurrence from UCS and copy UCS from part to assembly.
Sub Main()
Dim occDef As ComponentDefinition
Set occDef = oUCS.Parent
For Each occ In oDef.Occurrences
If occ.Definition Is occDef Then
End If
Next
If occMatrix Is Nothing Then
Debug.Print ("UCS occurrence not found")
Else
End If
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
is it possible to get the UCS from a part in a subassembly? How do I transforme the matrix?
Thank you
Georg
- Mute
- Permalink
- Report
Hi @GeorgK,
You could try the following VBA code. Here, only part occurrences are considered.
Sub Main()
For Each occ In oDef.Occurrences.AllLeafOccurrences
Exit For
End If
Next
Else
End If
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
