dgreatice
in reply to: NachitoMax
Yes you can. with this code:
Dim oDWGdoc as DrawingDocument
oDWGDoc = ThisApplication.ActiveDocument
Dim oSht as Sheet
'oSht = oDWGDoc.sheets.item(1)  'With index, result get sheet:1 ; or
'oSht = oDWFDoc.sheets.item("test:2") ' with name of sheet  ; pick one
'next you're code
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
