AlanBrock9115
928 Views, 4 Replies
Problem Printing to PDF from Ilogic 2018
Hi Guys
I have just upgraded to 2018.1 and have a global ilogic script (thanks to Curtis Waguespack). I made the tweaks to the code so that it produced PDFs which worked fine. The problem comes  when opening the PDF set and trying to extract a page or save as you get a cannot read file  (114) error. The PDF behaves normally in all other respects.
  If I print to PDF from Inventor it works fine and using the changed ilogic code in 2017 it also works.
I have included the code and hoping someone may be able to help.
We use Adobe Acrobat DC.
Many Thanks
trigger = iTrigger0
Dim oDrawing As DrawingDocument
oDrawing = ThisApplication.ActiveDocument
Dim osheet As Sheet
oPath = iProperties.Value("Summary", "Subject")
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oDescription = iProperties.Value("Project", "Description")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oMySheetCount = oDrawing.Sheets.Count
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Custom_Begin_Sheet") = iPageNumber
oOptions.Value("Custom_End_Sheet") = iPageNumber
oOptions.Value("Custom_Begin_Sheet") = 2
oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\"))' & "2521-Arapuni Diversion Gate Upgrade"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
 "-SET-"& oDescription &"["& oRevNum &"]" & ".pdf"
 On Error Goto handlePDFLock
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
ThisApplication.CommandManager.ControlDefinitions.?Item("AppFilePrintCmd").Execute
Exit Sub
handlePDFLock: MessageBox.Show("PDF could not be saved, most likely someone has it open ", "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
handleXLSLock: MessageBox.Show("No XLS", "iLogic")
Resume Next
'------end of iLogic-------
