Mark.Valenti
278 Views, 1 Reply
Help with copy design & unique file rename with vault on frame gen assys.....
Searching for the best way, or least cumbersome... I have used vault, ilogic, and design assistant.  All have their plus's and minuses... maybe I'm approaching it all wrong...
Workfow:
Create assy (module), create skeletal frame, build frame (custom content center extrusions), add stand alone parts, add content center parts..
naming convention
job number_module number_part name/number
16-024_UCW 1.1_000000031
File structure
16-024 (FOLDER)
      UCW_1.1(FOLDER)
          16-024_UCW 1.1.IAM
          16-024_UCW 1.1 SKELETON.IPT
          FRAME (FOLDER)
              16-024_UCW 1.1_FRAME.IAM
              16-024_UCW 1.1_000000031.IPT
              16-024_UCW 1.1_000000032.IPT
              16-024_UCW 1.1_000000033.IPT
The problem lies at the design copy stage...
I would like to change the prefix for each additional copy to new target folder...
From
to
16-024_UCW 1.2_000000031
I'm thinking the better way is to create a base design like this:
16-024 (FOLDER)
      UCW_1.1(FOLDER)
          MODULE.IAM
          SKELETON.IPT
          FRAME (FOLDER)
              FRAME.IAM
              000000031.IPT
              000000032.IPT
              000000033.IPT
Thoughts?
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
Please provide is a more detailed description of what you want to do.
I don't get e clue about what you need.
make a detailed step by step description for what you try to achieve and upload it.
Only then someone can try to help you.
Arthur Knoors
Autodesk Affiliations:
