10-18-2017
02:10 PM
- Mute
- Permalink
- Report
10-18-2017
02:10 PM
If you've ever head of 'implied solutions' and take into account the context - a public forum where every level of user is allowed to post - you would understand why asking why is a necessary step.
If there is so much complexity in one file put a trigger on a visible open to explain that it required certain steps to ensure the files are properly updated, or even attach them on save. This should suffice unless the file is used too frequently for this to be efficient (ie; multiple times a day), or is prone to causes unnecessary costs.
Again, like I said, maybe review the 'why' you need it and the 'how' you are currently doing it and you might come across a more elegant solution.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
