MechMachineMan
Something like this should work.
Dim doc as AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As ComponentDefinition = doc.ComponentDefinition
Try
oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("iLogic").Activate(True)
Catch nLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("iLogic") nLOD.Activate End try InventorVb.DocumentUpdate()
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
