10-17-2017
07:25 AM
- Mute
- Permalink
- Report
10-17-2017
07:25 AM
Based on the assosciated Imports and the languages, the required for enumerators are different.
In vba you can get away with just the enum, but in vb.net you need to put in the Enum Type.
The safest way across all languages is to just extract what the integer is and to use that instead.
This is not a bug/ this behavior is well known.
Try using the code below.
Sub Main() Dim oDoc As Document oDoc = ThisApplication.ActiveDocument Dim oCompDef As ComponentDefinition oCompDef = oDoc.ComponentDefinition oCompDef.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
