264 Views, 1 Reply
Custom balloons for wall panel
Show in the picture below are panel tagging of wall (W-IW-GL-01, etc. ).
Is there any way in Inventor to do the balloon like this?  No arrows and should be located inside the panel.
matt_jlt
Just a suggestion, does it have to be a balloon? It looks like a sketch symbol would work just as well without having to set up your custom styles. But the answer to your question is yes.
* Under the Manage Tab > Styles Editor Command
* In the styles editor there is a section in the browser panel to the left called balloons, if you expand the tree you can see the list of styles you have.
* You can modify your existing one but I would recommend you make a copy / new one (by right clicking on the existing style you use and click 'New Style')
* Once you have clicked on the style you want to modify, in the Balloon Style window, there is an area called balloon formatting.
* You can either change the shape to be rectangular or use a custom sketch symbol to define the new balloon shape.
Matt.
