- Mute
- Permalink
- Report
I have created my title block with 'prompted entries'. if I need to add a new sheet, how do I get those entries to automatically fill in so that I don't have to add those again?
Thank you
- Mute
- Permalink
- Report
iLogic.
Or change those fields from prompted entry to drawing properties (optional: and use an iLogic form to to fill them in)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
I figured out that I needed to use iLogic, I just haven't been able to get it to work for me. I am not too strong in the iLogic part of Inventor.
- Mute
- Permalink
- Report
try to change to normal properties which are filled out by Iproperties from Drawing or Model
- Mute
- Permalink
- Report
@Anonymous.cooper.osv wrote:
I have tried that. Didn't work.
Then you don't understand what we mean/aren't doing it correctly.
... OR you are trying to say the process isn't suitable for you.
- Mute
- Permalink
- Report
in your Drawing...
left side in the browser. click on drawingressources -> Titleblock -> choose your Titleblock -> right mosue click edit
in my case the DIN titleblock
now you should see the Definition of Titleblock, otherwise you have imported a dwg or something like that, and that you have to create a new one.
you should see something linke this
There you click on your attribut which you want to fill out automatically, in my case part number.
There you can choose which iproperty you want to link, after you have choose your irpoperty, klick on the small button right site of them. the X with the small down arrow. than the attribut should be added in the textbox.
click ok and close the sketch. and you should see the iproperty in your block, if its exisitent.
otherwise we need more informations, which information you want to use in your titleblock
- Mute
- Permalink
- Report
