10-10-2017
12:14 PM
- Mute
- Permalink
- Report
10-10-2017
12:14 PM
There is no easy solution for this.
I checked using the VBA editor to see what objects are accessible from the SketchedSymbol, and the parent is in fact always the sheet.
Also, there is never any view information that gets associated with the sketched symbol; the closest you can get is the coordinates of the leader points which attach it to something.
This leaves you with the whole trouble of trying to find what object on the sheet actually has a line or point at those same coordinates.
This means Rikard's solution is likely as close as you are going to get unless you find a better way to get the associated object for 2 given work points.
Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
