233 Views, 1 Reply
iLogic Error
I've got some code to update the copied iproperties in a drawing that works when run manually but gives an error when triggered.
The code:
Dim oControlDef as ControlDefinition
oControlDef = ThisApplication.CommandManager.ControlDefinitions.​Item("UpdateCopiedModeliPropertiesCmd")
oControlDef.Execute2(True)
Thanks!
bradeneuropeArthur
Change this:
oControlDef.Execute
Arthur Knoors
Autodesk Affiliations:
