10-04-2017
02:44 AM
- Mute
- Permalink
- Report
10-04-2017
02:44 AM
Imports SysIO = System.IO
Sub Main()
'Check pre-processing conditions. If (ThisApplication.Views.Count = 0) Then: Exit Sub: End if Dim DWGAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}") Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = kFileBrowseIOMechanism
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
For Each oVisDoc As View In ThisApplication.Documents.VisibleDocuments If oVisDoc.DocumentType = kDrawingDocumentObject Then
DocName = SysIO.GetFileName(oVisDoc.FullFileName)
Dim dwgDir = SysIO.Path.GetDirectoryName(oVisDoc.FullFileName)
oDataMedium.MediumType = kFileNameMedium
oDataMedium.FileName = dwgDir & iProperties.Value(DocName, "Project", "Part Number") & " Rev. " & iProperties.Value(DocName, "Project", "Revision Number") & ".dwg"
If DWGAddIn.HasSaveCopyAsOptions(oVisDoc, oContext, oOptions) Then
Dim strIniFile As String = "C:\Export Copy Main Directory\dwg\Format2000DONOTDELETE.ini"
oOptions.Value("Export_Acad_IniFile") = strIniFile
Call DWGAddIn.SaveCopyAs(oVisDoc, oContext, oOptions, oDataMedium)
End If
End If
Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
