mcgyvr
@Anonymous wrote:
I have an assembly and we are able to modify the BOM list by iLogic. How can I replace only that components which are active in the model history and ignore the models which are not found?
Thanks in advance
Here is the example page for component functions with ilogic..
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-AFA099F1-B161-4822-914D-307F5CD8FE20
See if that helps you..
You might want to be more specific with your example to let us know how Inventor will know which part should be replaced with what? excel file?
Is it supposed to find a specific part only and replace it or what
