09-28-2017
11:38 AM
- Mute
- Permalink
- Report
09-28-2017
11:38 AM
Your iProperties.Value call only ever grabs from the ACTIVE document. You need to DIRECT it to each document to grab that specific documents name.
Instead of
iProperties.Value("Project", "Part Number")
use
iProperties.Value(SysIO.Path.GetFileName(view.Document), "Project", "Part Number")
Good luck!
PS: You would have to call view.Document.Activate for every new document during the loop in which you process it, which is very time consuming to make it work with just the base iProperties.Value() call. But no one wants this, so use the info provided above instead.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
