JamieSENG
in reply to: JamieSENG
So i got the location and filename sorted. Only now when i run the code the exported files keep the first filename and overwrite one another. Could you take a look...
Imports SysIO = System.IO
Sub Main()
'See if there are any open views
If (ThisApplication.Views.Count > 0) Then
'Setup Translator to dwg
Dim DWGAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Go through each view and save if it's a drawing document
For Each view As View In ThisApplication.Views
If view.Document.DocumentType = kDrawingDocumentObject Then
'Get the directory file is saved in. Can replace this with specific directory
Dim dwgDir = "C:\Export Copy Main Directory\dwg\"
'Get name Of file without the extension And add _acad2k To it.
oDataMedium.MediumType = kFileNameMedium
oDataMedium.FileName = dwgDir & iProperties.Value("Project", "Part Number") & " Rev. " & iProperties.Value("Project", "Revision Number") & ".dwg"
' Check whether the translator has 'SaveCopyAs' options
If DWGAddIn.HasSaveCopyAsOptions(view.Document, oContext, oOptions) Then
'Use Export To DWG to save drawing configuration and set here
Dim strIniFile As String = "C:\Export Copy Main Directory\dwg\Format2000DONOTDELETE.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
'Save File
Call DWGAddIn.SaveCopyAs(view.Document, oContext, oOptions, oDataMedium)
End If
End If
Next
End If
End Sub
