MechMachineMan
Again, searching for help is step 1.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-7AF9FEE7-D326-49C8-87CC-D5498EA49194
As SHOWN in the link (ie; ONLINE HELP), the ActiveAppearance property is of the ASSET type, not a STRING like you are attempting. If you read further into the asset object type, or even through the parents of appearance/asset, you should be able to find out how to access the appearance asset by name (even it it means iterating through a large collection and checking for an equality based off of a name property or something similar).
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
