09-22-2017
12:29 AM
- Mute
- Permalink
- Report
09-22-2017
12:29 AM
To test is a file is an iPart I use:
SyntaxEditor Code Snippet
Dim partDoc As PartDocument = ThisApplication.ActiveDocument If partDoc.ComponentDefinition.IsiPartFactory Or partDoc.ComponentDefinition.IsiPartMember Then MessageBox.Show("This IS an iPart", "Title") Return 'do nothing Else MessageBox.Show("This is NOT an iPart", "Title") End If
But what do I need to check if it is an iPart or an iAssembly?
I like to run some iLogic on my files, but not on the iPart or iAssembly files.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
