09-08-2017
11:04 PM
- Mute
- Permalink
- Report
09-08-2017
11:04 PM
LOCAL HELP INVENTOR
Local help doesn't work if I have microsoft edge as default internet browser.
How can I fix that
Thank you
Antonio Domit
09-09-2017
07:17 PM
- Mute
- Permalink
- Report
09-09-2017
07:17 PM
2 options AFAIK
1. Use the .chm file that is found in %Public%\Documents\Autodesk\Inventor 2017\Local Help
2. Use the website. http://help.autodesk.com/view/INVNTOR/2018/ENU/?query=inventor%2Bapi&cg=Developer%27s%20Documentatio...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
