MechMachineMan
in reply to: Owner2229
If this is the "file is reserved" issue, here is a script you can run that will "fix it". I had tried programmatically other ways, but couldn't find anything.
It could be removed manually by doing a SaveCopyAs on the file, so I resorted to this workaround.
Sub Main()
	Dim oTempFolder As String = System.IO.Path.GetTempPath() 'ending with \
	Dim oDoc As Document
	oDoc = ThisApplication.ActiveDocument
	If oDoc.ReservedForWrite = True
		resp = MsgBox("File is reserved for write. Remove this?", vbYesNo, "MMM iLogics")
	Else
		resp = MsgBox("File is NOT reserved for write. Save a duplicate copy over this file?", vbYesNo, "JRK iLogics")
	End If
	If resp = vbYes
		oFName = oDoc.FullFileName
		oTempFileName = oTempFolder & System.IO.Path.GetFileName(oFName)
		oDoc.SaveAs(oTempFileName, True)
		oDoc.SaveAs(oTempFolder & "[BACKUP]" & System.IO.Path.GetFileName(oFName), True)
		'Process.Start(oTempFolder)
		System.IO.File.Delete(oFName)
		System.IO.File.Move(oTempFileName, oFName)
		ThisApplication.FileManager.RefreshAllDocuments()
	End If
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
