MechMachineMan
in reply to: sguan1212
1. That requires iLogic/programming and nothing to do it "automatically"/"link" it. You would have to set up event triggers for it.
2. There is no way I'm aware of. Multiple Assemblies per dwg seems like a bad idea to begin with. Multiple parts is not that bad. At the very least, put each assembly on a new page. The only way around this is to us a sketched symbol that is 100% prompted entries and manually type in the info, or go through the pain of developing an add-in to make it happen.
It's definitely easier to change your standards to match out of the box functionality so that you do not have to learn/maintain the programming aspect.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
