chandra.shekar.g
in reply to: navbor
Hi @navbor,
Try the following VBA code.
Sub Main()
    Dim oDef As ComponentDefinition
    Set oDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim baseView As DesignViewRepresentation
    Dim targetView As DesignViewRepresentation
    Set copyDesign = oDef.RepresentationsManager.DesignViewRepresentations.Item("Bottom") ' View1
    Set oView = oDef.RepresentationsManager.DesignViewRepresentations.Item("Left") ' View 3
    Call CopyDesignView(copyDesign, oView)
End Sub
Sub CopyDesignView(ByVal baseView As DesignViewRepresentation, ByVal targetView As DesignViewRepresentation)
    Dim targetViewName As String
    targetViewName = targetView.Name
    Call targetView.Delete
    Call baseView.Copy(targetViewName)
End Sub
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
