YuhanZhang
in reply to: martinhoos
You can refer to Excel API to do this, below is sample code:
Sub ExcelInsertPDFMacroSample()
    Dim oWB As Workbook
    Set oWB = Application.ActiveWorkbook
    ' activate the first work sheet.
    oWB.Sheets(1).Activate
    ' insert the PDF at the A1 cell
    Range("A1").Select
    ' insert as embedded object
    ActiveSheet.OLEObjects.Add(Filename:="C:\Temp\MyPDF.pdf" _
        , Link:=False, DisplayAsIcon:=False).Select
    ' insert as linked object
    'ActiveSheet.OLEObjects.Add(Filename:="C:\Temp\MyPDF.pdf" _
        , Link:=True, DisplayAsIcon:=False).Select
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
