martinhoos
716 Views, 4 Replies
insert images excel
Hello, i create a PDF file from a IDW and i create a excel file and insert the boom from the IDW. Is it possible, i dont know how, to insert the PDF file onto a new worksheet (sheet1)?
Thanks for the help!
Regards Martin
YuhanZhang
in reply to: martinhoos
You can refer to Excel API to do this, below is sample code:
Sub ExcelInsertPDFMacroSample()
    Dim oWB As Workbook
    Set oWB = Application.ActiveWorkbook
    ' activate the first work sheet.
    oWB.Sheets(1).Activate
    ' insert the PDF at the A1 cell
    Range("A1").Select
    ' insert as embedded object
    ActiveSheet.OLEObjects.Add(Filename:="C:\Temp\MyPDF.pdf" _
        , Link:=False, DisplayAsIcon:=False).Select
    ' insert as linked object
    'ActiveSheet.OLEObjects.Add(Filename:="C:\Temp\MyPDF.pdf" _
        , Link:=True, DisplayAsIcon:=False).Select
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
martinhoos
in reply to: YuhanZhang
Hi Rocky,
thanks a lot for your reply. Is it possible to get your code as iLogic-code? So i can place it in better.
Regards
Martin
YuhanZhang
I am not sure how iLogic can reference to Excel API in iLogic rule, but below is a sample for you to call Excel API via Inventor VBA Editor, you can add the reference(Tools->References...) to "Microsoft Excel xx.0 Object Library" in VBA Editor, the xx is the version of the Excel, and then in Inventor VBA run below macro:
Sub InsertPDFSample()
    Dim oExcel As Excel.Application
    On Error Resume Next
    Set oExcel = GetObject(, "excel.application")
    If Err.Number <> 0 Then
        Set oExcel = CreateObject("excel.application")
    End If
    oExcel.Visible = True
    Dim sExcelPath As String
    sExcelPath = "C:\TEMP\Test.xlsx"
    Dim oWorkbook As Excel.Workbook
    Set oWorkbook = oExcel.Workbooks.Open(sExcelPath)
    oWorkbook.Sheets(1).Activate
    oWorkbook.Sheets(1).Range("A1").Select
    oWorkbook.ActiveSheet.OLEObjects.Add(FileName:="C:\Temp\MyPDF.pdf" _
End Sub
Rocky Zhang
Inventor API PD
Autodesk, Inc.
martinhoos
Thank you very much.... !
Regards Martin
