657 Views, 2 Replies
AddIn Automation Interface problem
HI
I have this error when I try to call the AddIn from the other application:
Unable to cast COM object of type 'System.__ComObject' to interface type 'HInventorServer2013.IAutomation'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{89D1FA61-3CEB-365D-A1F5-9A664F525CCB}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
I tried many different things but nothing works until now.
The AddIn is here:
C:\Users\me_as_user\AppData\Roaming\Autodesk\ApplicationPlugins\HInventorServer2013
Maybe I have to register the DLL generated from the StandardAddInServer?
I don't know what else to do.
Paolo
This is for inventor 2013 but i didn't works also for Inventor 2017
Implementation is very easy, nothing fancy:
[GuidAttribute("88095ac1-6393-458d-8327-c168f027da88")]
public class StandardAddInServer : Inventor.ApplicationAddInServer, IAutomation
private Inventor.Application _AddInApp;
private string _AddInGuid = "{88095ac1-6393-458d-8327-c168f027da88}";
public StandardAddInServer() {}
public void Activate(Inventor.ApplicationAddInSite addInSiteObject, bool firstTime)
  _AddInApp = addInSiteObject.Application;
public void Deactivate()
    // Release objects.
    Marshal.ReleaseComObject(_AddInApp);
    _AddInApp = null;
    GC.WaitForPendingFinalizers();
    GC.Collect();
public void ExecuteCommand(int commandID) {}
public object Automation
    get { return this; }
// Interface implementation
public string HI_GetCurrDocument()
    PartDocument doc;
    // Container pippo = new Container();
    string text = "";
    try
        doc = _AddInApp.ActiveDocument as Inventor.PartDocument;
        text = doc.DisplayName;
        // pippo.GetContainer = doc.DisplayName;
    catch (Exception e)
        // pippo.GetContainer = e.ToString();
        text = e.ToString();
    return text;
public string HI_GetSketchLines()
    Container test = new Container("ciao da API");
    return test;
    return "Hello from API";
and this is the call
public CallAddIn()
    try
        _InvApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") as Inventor.Application;
    catch
        Type InvAppType = System.Type.GetTypeFromProgID("Inventor.Application");
        _InvApp = System.Activator.CreateInstance(InvAppType) as Inventor.Application;
    _InvApp.Visible = true;
    // hard coding Guid of the AddIn
    string AddInGuid = "{88095ac1-6393-458d-8327-c168f027da88}";
    ApplicationAddIn InvAddIn = _InvApp.ApplicationAddIns.get_ItemById(AddInGuid.ToUpper());
    // make sure addIn is activaded
    if (!InvAddIn.Activated)
        InvAddIn.Activate();
    // this works - InvAddIn is correct
    Debug.Print(InvAddIn.DisplayName);
    // version 1 - this give me an error
    IAutomation HIapi = (IAutomation) InvAddIn.Automation;
    // this give a null object - conversion failed
    IAutomation HIapi = InvAddIn.Automation as IAutomation;
Only to extend the discussion, I tested the Add in with a simple form application but it load the dll in a very strange ways
TestAddIn
Versione assembly: 1.0.6444.27930
Versione Win32: 1.0.6444.27930
Base di codice: file:///C:/Users/p.cappelletto/Documents/workspace/VisualStudio2012/TestAddInApp/TestAddInApp/bin/Debug/TestAddIn.DLL
.DLL???? Could be this the problem?
P
Tags (3)
I think that for using Automation it's mandatory redister the AddIn's DLL.
I tried different solutions but in my case it works only on this way.
If someone else had the same problems I would like to know alternative solutions.
P
