08-21-2017
02:24 PM
- Mute
- Permalink
- Report
08-21-2017
02:24 PM
There is a code sample that's supposed to get the value Part Number:
SyntaxEditor Code Snippet
Public Sub GetPropertySample() ' Get the active document. Dim invDoc As Document Set invDoc = ThisApplication.ActiveDocument ' Get the design tracking property set. Dim invDesignInfo As PropertySet Set invDesignInfo = invDoc.PropertySets.Item("Design Tracking Properties") ' Get the part number property. Dim invPartNumberProperty As Property Set invPartNumberProperty = invDesignInfo.Item("Part Number") MsgBox "Part Number: " & invPartNumberProperty.Value End Sub
I tried to put it in my code below:
Dim oDoc As PartDocument oDoc=ThisApplication.ActiveDocument Dim oCompDef As SheetMetalComponentDefinition oCompDef=oDoc.ComponentDefinition Dim oDataIO As DataIO oDataIO=oDoc.ComponentDefinition.DataIO If oCompDef.HasFlatPattern=False Then oCompDef.Unfold Else oCompDef.FlatPattern.Edit End If Dim sOut As String sOut="FLAT PATTERN DWG?AcadVersion=2000" _ +"&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL" _ +"&SimplifySplines=True" _ +"&LINEAR TOLERANCE=0.010" _ +"&MergeProfilesIntoPolyline=True" _ +"&RebaseGeometry=False" _ +"&TrimCenterlines=True" Dim invDesignInfo As PropertySet invDesignInfo=oDoc.PropertySets.Item("Design Tracking Properties") Dim invPartNumberProperty As Property invPartNumberProperty=invDesignInfo.Item("Part Number") Dim sFname As String sFname=invPartNumberProperty & ".dwg" oCompDef.DataIO.WriteDataToFile(sOut,sFname)
But I get an error on Line 22 (Dim invPartNumberProperty As Property) that says:
Keyword does not name a type.
I am lost on what this means. I also noticed that when I type in "Property" it turns red and begins an outline ticker, is that what's causing the Keyword error? Am I supposed to close this with a "End Property" line or something. It honestly should not be this difficult to get the Part Number into an object or string so I can use it as the file name when I export the dwg.
