MechMachineMan
in reply to: philip1009
Likely what you need to do is access the document's component definition, check isiPartmember, then iterate through the rows using the available function calls. You will be able to use the changerow call to swap through each iPart, and use the .Row property to grab the part number for that item.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-FE230CC1-D9A7-4050-9018-2BBE35941067
or it might be the same, but using the iPart factory things. Not too familiar with anything else, but you should be able to find some samples within the programming help resources.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
