Cadkunde.nl
415 Views, 3 Replies
Turn off model sketches in drawing
Hello everyone, I got the following problem:
I have a drawing with 1 view of a part.
I get the model sketches of that part in a drawing view
If you right click that sketch you can choose "Include" and "Visible"
Now I made the following code in ilogic:
Sub Main()
    Dim oDoc As DrawingDocument = ThisDoc.Document
    Dim oSheet As Sheet = oDoc.ActiveSheet
    Dim oNode As BrowserNode = oDoc.BrowserPanes("Model").GetBrowserNodeFromObject(oSheet.DrawingViews.Item(1))
    Call recurseNodes(oNode)
End Sub
Sub recurseNodes(node As BrowserNode)
    Dim bn As BrowserNode
    For Each bn In node.BrowserNodes
            If TypeName(bn.NativeObject) = "PlanarSketch" Then
                bn.Visible = False
                MsgBox(bn.Visible)
                Dim oSketch As PlanarSketch = bn.NativeObject
                oSketch.Visible = False
                MsgBox(oSketch.Visible)
                Dim oProxy As PlanarSketchProxy = TryCast(oSketch, PlanarSketchProxy)
                If oProxy Is Nothing Then MsgBox("fail")
            End If
            If Not TypeName(bn.NativeObject) = "DrawingView" Then
                Call recurseNodes(bn)
            Else
                Continue For
            End If
    Next
End Sub
Now the messageboxes say that sketches are turned off,  but in truth nothing happens, sketches remain on.
What am I doing wrong?
Thanks in advance,
Arnold
