MechMachineMan
in reply to: awatt
VB and VBA are so interchangeable there should be no hang-ups between using the two language.
What it sounds like you are more concerned about with whether there is functionality in the Inventor API. Which is yes. Which means you can use the language of your choice to programming something to do the task you wish.
A little more searching on the forums and you find that I have written for previous solutions both scripts that will delete existing iLogic rules, copy iLogic rules, and another sheet of documentation to show available iLogic calls.
Using these things, you should be able to piece together the solution for what you want.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
